How to loosen nipple from sink to main drain
Old 12-27-05, 11:07 AM
Maxjakes
trying to remove old nipple from sink drain into drain line. Both are cast iron and very old. Nipple willnot budge, is there any tip for getting it loose?
Old 12-27-05, 11:19 AM
majakdragon's Avatar
Maxjakes, Welcome to the DIY Forums.
The nipple SHOULD be galvanized pipe and threaded into the cast iron fitting in the wall. It is, no doubt, corroded. Try tapping lightly on the pipe with a hammer as you put pressure on the nipple with a pipe wrench. Vibration works great for loosening corrosion. Good luck.
