Installing Tile Shower Drain(is a vent needed)
Old 12-28-05, 07:01 AM
dhkwftw
We removed a Tub and are converting the space to a tile shower. I am installing a new drain, and I am going to use the existing tub drain pipe. The tube had a vent pipe tied in to the drain. Due I need to install a new drain pipe for the shower. The old shower didn't have one and it appears that all of the fixtures are tied into 1 vent for the whole bathroom.
Old 12-28-05, 07:26 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
Each fixture requires it's own vent. The vents all tie into the main ventline after leaving the fixture.
Not sure where you live, however, most areas require a 2" drain for showers (all the way to the main drain). Tubs, even with a shower included, are only required to have 1-1/2" drains. Good luck.
