Easy way to pipe drain to larger new tub??
We are remodeling our bathroom, and are interested in putting in an oversized tub. Original is the 30" wide standard, but tub we are considering is 36". Moving the copper supply to the fill valve and shower piping will be easy enough, but the drain will be much harder.
The drain piping is all glued PVC, but there is another tub on the opposite side of the wall, so the fittings are very tightly installed in the wall space and I may have to re-pipe the entire drain line to both.
Are there any fittings available to simply offset the drain and overflow pipe for a 30" tub over 3" to accomodate a larger 36" tub?
