One sink to two conversion (piping question)
Old 01-01-06, 10:40 PM
jim321
I'm doing a complete bathroom remodel and I'm switching from one sink to two. I'm not sure how the piping should be routed. Both the drain pipes and water supply lines as well. I know the Rough in measuraments, I'm looking for advice on how all the piping should come together. Thanks in advance.
Old 01-02-06, 07:36 AM
shacko's Avatar
Sink
Are we talking about a two bowl vanity? Not inough info. If you tell us what you are trying to do we may be able to help.
Old 01-03-06, 04:06 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Since you haven't done your drains or supply yet, then you should be able to give each sink its own drain and supply lines. Drains should be 1 1/2" from stub out to the main drain, and you should use 1/2" supply lines from your main supply.
Old 01-08-06, 09:04 PM
jim321
one sink to two conversion
Thanks for the info, but here is my question. Do I install separate supply lines to each sink and run them to the 3/4 pipe ( to & from the hot water heater ) OR do I run a tee off of one set of the 1/2 lines and Then connect them to the 3/4 pipe ( to and from the hot water heater ) I'm aware that the supply line is 1/2 inch. When I look in my "how to" book, It shows a basic " rough in" drawing of supply lines for one sink but not for two sinks. Also, will it make a difference in water pressure by adding a double sink? Thanks again for your help.
