washing machine - cold water dribbles in
Old 01-13-06, 02:17 PM
P
Question washing machine - cold water dribbles in
For a few weeks now when I selected warm/cold, the warm is piping hot and the cold just dribbles in and takes over an hour to fill the tub.
I took the faucet off and tried turning the part that the handle turned with a wrench. Still no more flow. Any ideas? Thanks.
Old 01-13-06, 02:53 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
phyllis, Welcome to the DIY Forums.
I am a bit confused on what you did to the faucet. Did you disconnect the hose and turn on the faucet to see if the water flowed properly? I am trying to figure out if it is a washer problem or a water supply problem. Let us know. Good luck.
Old 01-13-06, 08:10 PM
P
Question washing machine cold water inflow problem
Thanks for replying, dragon.
All I did to the faucet was unscrew the bolt holding it on. I was going to see if the washer was bad, but it seemed OK. Then I dropped the bolt/screw behind the washer!
I tried to operate the inflow with a wrench. It turned both ways but the volume didn't change.
Yes, I am not a plumbing person.
Phyllis
Old 01-13-06, 09:58 PM
fixitron's Avatar
Disconnect the cold water supply hose from the washer. Inside the male end at the washer you should find a screen that is probably clogged with debris. If it is, pull it out with needlenose pliers and get a replacement screen/washer at your hardware store.
Old 01-14-06, 06:26 PM
P
Red face Thanks Fixitron
I will try your suggestion when I get home from the weekend. It makes perfect sense. Thanks!
