any tricks for cleaning out rotten cast iron threads
Old 01-16-06, 04:07 PM
B
Ok, so I took out my old steel tub and am replacing with a new one, and the thing must have been in there 40 years, because when I took the old one out, the cast iron p-trap pipe just fell to the ground(crawl space). The old male fitting was badlly rusted and bonded to the female threads. I picked up something called mouse milk at the plumbing supply and that helped a lot to clean out the majority of the male threads, but not all. Can anyone provide me some advise on removing the last bit of remaining cast iron threading from the female fitting where the tub p-trap line ties into the main sewer line?
Also, I'm planning on using ABS for the new p-trap. Currently the threads of the male abs fitting go in about half a rev before stopping hard. How much of an issue is it if I can't clean the old threads out completely?
Thanks
Brian
Old 01-16-06, 04:53 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
If you do not get the threads cleaned out, it will leak. Try calling a plumbing shop and ask if they have a pipe tap the size of the fitting. They may "chase" the threads for you. Not likely you will find a tool rental place with a pipe tap but you might try. Good luck.
Old 01-16-06, 05:23 PM
B
I figured as much, but the pipe tap was so expensive for a one-off, was trying to avoid that. Hadn't thought about asking to borrow one. Can't hurt I guess - will give it a try
Thanks!
Brian
Old 01-18-06, 01:24 AM
bolide's Avatar
Lightbulb make your own thread chaser
Definitely you should thread in a metal pipe and remove it before you try to thread in plastic.
The mouse milk should have loosened the rust.
A steel (black iron) nipple with tapered (NPT) ends should cost about $2.
You could carefully cut a big notch intothe nipple from one end using a high-speed grinder and a grinding wheel.
The notch should give the rust a place to escape or perhaps bend the rotted remains enough that you can grab them with pliers.
Wind your home-made tap in and out until you work everything loose that is blocking the threads.
Once the notched end screws in and out, switch to the factory end and repeat.
Be very careful that the ABS doesn't crossthread going into the imperfect old threads. Use a soft joint compound (pipe dope) for the final connection.
