Planning a quiet 2nd floor bathroom
Hello!
In the process of planning a new second floor bathroom (shower, sink & toilet). The current plan is to position the toilet so the 3" drain will closet bend horizontal, then connect into a sanitary tee heading downward through an existing first floor wall. (The floor joists are 2x8's, so there's not a lot of room to spare). The sanitary tee will then go upwards into 2" PVC for the vent which will either tie into an existing 2" house stack or go up through the roof itself.
The shower will be a 2" trap and drain into the same 1st floor wall and then connect inside the wall with a Wye. Same concept that the 2" vent will connect back into the toilet vent and through the roof.
So first off, am I missing anything important? Any pitfalls working in such a small joist space?
Also, I'm concerned about water noise on the first floor. The first floor wall is the hallway and dining room, so I don't want to hear every time someone uses the upstairs bathroom while having thanksgiving dinner.
I've read that no-hub iron reduces water noise, and I'm thinking of running the copper supply pipes a more indirect route as to not have them in that wall.
Thoughts?
Thanks in advance for any suggestions you can provide.
-Mike
Thoughts?
-Mike
A 2" pipe has one-fourth the capacity of a 4" pipe.
The pipe will fit much better and the trap doesn't drop as far.
Plus it stays another 0.25" higher on horizontal connections and runs.
2" pipe takes almost twice as much space as 1.5".
I appreciate the feedback. The wealth of information in this forum coupled with Rex Cauldwell's book, I think it's all starting to make sense.
I will have to reconfirm the 2" vent, now that I think through it, there's probably a 4" stack for the house vent, and then another existing 2" vent for two or three of the first floor fixtures. How many fixtures can be vented in one 2" pipe? Or would I be better off with a new 2" roof vent for the shower, tub & toilet?
Also, other than using 3/4" piping copper for the supply up the same wall, any recommendations to keep the supply pipe noise to a minimum?
Thanks again for all your help.
-Mike
-Mike
