water level
Old 02-01-06, 01:34 PM
water level
hello........
how do you adjust the water level in the toilet (push button). It seems low in the pan thanks john
Old 02-01-06, 02:50 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
If you are referring to the level in the bowl (pan), there is not a way. The trap in the bowl decides how much water it holds. Water in the tank is adjusted with the ball/arm or with the fill valve adjustment. Good luck.
Old 02-01-06, 04:39 PM
bolide's Avatar
Make sure the little tube from the valve to the overflow it connected and running a full stream.
Old 02-02-06, 11:59 AM
push flush
thanks all
It all works ok just seems like the water level is low in the pan.
Old 02-02-06, 01:13 PM
The trap in a toilet is the same as under a sink. It is "U" shaped and only holds enough water to block sewer gases from entering the home. Any excess water flows down the main drain.
