bubbling toilet
Old 02-18-06, 07:41 AM
T
TJA
TJA is offline
bubbling toilet
Whenever the third floor washer is on its rinse cycle, the water in the vented basement toilet bubbles and detergent foam even appears when the wash has completed. When the basement toilet is flushed while the washer is on a rinse cycle, the toilet level rises to the rim.
I've had the city run a camera through the sewer line from the house to the street and it was clear and, as well, I've had the line from the toilet to the sewer probed and that portion was also clear.
While the problem is annoying, it has persisted and mystified several plumbers.
Now this toilet was poorly installed at the outset by a subcontracted "professional" and discovered and rectified after a prolonged and unpleasant nightmare with sewer rats/maggots/flies/odour.
Any suggestions?
Thanks, in advance.
Old 02-19-06, 09:14 AM
bolide's Avatar
Received 1 Upvote on 1 Post
What do you mean by "vented"?
Should we ask to hear the rest of the sad history?
Might there be another clue?
Old 02-19-06, 10:59 AM
T
TJA
TJA is offline
bubbling toilet.
Vented as in a vent out side with a stack running up through the house eve.
The line had just a minimal amount of water lying in it.
Old 02-19-06, 11:58 AM
bolide's Avatar
How far away?
What happens if you run a garden hose into the toilet?
Old 02-19-06, 02:00 PM
T
TJA
TJA is offline
bubbling toilet
I believe the vent is, at most, 3 feet away from the toilet......
When I ran a hose into the toilet, the water in the bowl drained continuously without ever rising.
Someone suggested running a hose down the vent (to ensure there isn't a blockage there) which I may do come spring.............should the water simply run through the line or will it also fill the bowl?
Old 02-19-06, 07:11 PM
bolide's Avatar
Lightbulb suds pressure zone
And if you flush the toilet too?
Could have been myself.
It should.
That's the mystery, isn't it.
Okay, this makes sense now.
Do you by chance have soft water?
Can you use less detergent when you wash your clothes?
Detergents these days are quite concentrated.
Your sewer line is filling with foam and burping it into the toilet.
It might be a vent problem. But I bet you have too much suds.
Old 02-20-06, 06:04 AM
T
TJA
TJA is offline
bubbling toilet
Beats me. However, considering that this is the "Limestone City", I suspect it is hard.
Can you use less detergent when you wash your clothes? Worth a try. We use the Costco brand, Kirkland in Canada).
Worth noting-when the washer is on rinse, the nearest sink drain also "burps."
