shower valve started making noise - normal?
We recently remodeled our master bath replacing a combo shower/tub - with a walk-in shower. This required rerouting some of the water pipes as the control is in a different location. We installed a new Moen scald guard single handle valve on a wall as you walk into the shower and the shower head is on a different wall opposite it, so the supply pipes have to travel around a corner from the valve to the head. Today it started making a small hissing noise - similar to a toilet running but much quieter. I took the handle and the escutcheon (sp?) - coverplate off and checked for leaks - no water but it's still making the noise. I never noticed it before and at first thought some sort of bug was just outside the window of the bathroom, but tracked it to the valve. My question is, is this a normal operating noise of the valve or should I be worried about a bigger problem? The shower still operates normally. I did try letting the shower run for a while on hot in case it was some sort of scald guard issue, but that did not resolve the noise.
As there were no leaks evident, I put it all back together and left it alone, but I was just a little concerned as it never did this before. Thanks in advance for whatever insight you can give me!
