how to connect plastic DWV pipe to 1940's cast iron DWV
Old 03-07-06, 09:18 AM
F
ok i am renovating parts of a 1940's wood frame building and it has the old 40s style cast iron hub and spigot with lead and oakum joint type of DWV piping system
well years ago in my younger days i removed a couple stacks that used ot serve as venting for some of the upstairs drainage
i took them down all the way down to the concrete slab floor in the ground floor, they have a 45 degree Y
see part D of this illustration:
http://www.tpub.com/content/engineer...4069_288_1.jpg
its not a true Y, its the Y that runs straight up to and through the roof, and the branch is the 45 degree and has a cleanout plug threaded in it, just above the concrete slab
well now i want to rebuild a small basic bathroom at/above(upstairs and exactly how it was originally) one of these stacks and i cant get the lead and oakum out of the bell/hub so that i can put in schedule 40 pipe and run it through the roof and such
what do i do ?
what is the trick to getting this lead and oakum out of the hub ?
it seems impossible
how did they do it ?
and when i put the schedule 40 pipe into the hub what do i used to pack/seal it ?
i cannot use hubless or anything else, as the Y is in the concrete
it is 4" by the way
will the sch 40 4" even fit inside the 4" iron hub ? or am i gonna be in trouble here?
thanks for anything
Old 03-07-06, 09:35 PM
bolide's Avatar
Received 1 Upvote on 1 Post
Too bad you removed that old pipe.
Get it really hot.
Patience.
> and when i put the schedule 40 pipe into the hub what do i used to pack/seal it?
Several choices.
Rubber doughnut or (e.g., Black Swan) soil pipe cement.
You can dig out the concrete.
> it is 4" by the way
They are the exact size. 4" IPS.
3" will work just fine and is easier to work with.
You can bush to 4" at the bottom.
