How Tight To Tighten A Pvc Fitting To A Brass Fitting
Old 03-08-06, 03:15 PM
trimman
I Have A Male Threaded Pvc Fitting That I Was Going To Conect To A Brass Fitting.my Question Is How Many Turns Do You Turn It Past Hand Tighten. Also I Was Woundering Do You Use Teflon Tape And Pipe Dope Or Just One Ot The Two.i Also Have A Brass Fitting I Want To Conect To A Outside Hose Bib. Same Question For It.
Old 03-08-06, 05:06 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
Use teflon or pipe dope on both jobs. Tighten the PVC just slightly more than hand tight and check for leaks. Easier to tighten more than replace the fitting. Brass, I don't think you will break it but you don't have to kill it either. Tighten firmly. Good luck.
