how do i rough in a bathroom sink
Old 03-14-06, 03:38 PM
N
the old bathroom sink and toilet had flared end pipes and no valves. i want the new bathroom to have 2 valves under the sink and 1 behind the toilet so i can shut the water off without closing the main downstairs.
i wamt to put those valves in right away so i can open the main shutoff downstairs and have water in the kitchen while i finish tearing out the old bathroom. i'm not tiling so i was thinking i could put the valves and it wouldn't be so hard to fit some greenboard around the valves after.
but i also got some extra caps. but if i cap the end of the line instead of putting a valve, can i heat the pipe again after, switch the cap for the valve.. or is that asking for trouble? i want everything to work and look right you know
here is a picture of the current bathroom plumbing. i bought pipe and all the fittings i need to put it back exactly the same.
http://img76.imageshack.us/img76/3223/dscf12076dl.jpg
i also want to know why do the pipes to the sink keep rising higher after the T's that go to the faucet? i guess i'm going to do it the same way
is there a correct height where i should put a T and have the pipes coming out of the wall? they have different lengths of the braided water lines at the store but i want to do it right.
and how far should the copper pipe come out of the wall so i can make a clean fit with my valve? i'm going to put a sink with drawers and stuff but the one for the toilet will be showing so i want it to look right.
Old 03-14-06, 07:26 PM
bolide's Avatar
Received 1 Upvote on 1 Post
Stubs are easier since the holes are smaller.
Yes.
Shock absorbers. They are supposed to have air in them.
Yes.
No.
The higher you put them, the shorter the supply lines.
But remember that you want to be clear of the bowl and drain/trap for ease of access.
The farther the easier it is to work with. Give yourself 8". You can always cut it shorter later.
In that case, probably 2". Is it a 90° valve? measure where your tank will be and line it up so the valve is under the center of the tank (front-to-back) and not at all to the left of the tank (your left as you face it).
Old 03-14-06, 09:05 PM
N
i will do it like that and give myself a few extra inches. i don't think i have the right valves anyway.
i did get all 90's. with a copper sweat inlet, and the out is male/threaded to connect with the braided supply line. i thought i would solder the valve right onto the copper pipe but i went and bought another plumbing book adn this book says to solder a threaded fitting onto the end of the copper pipe, then twist the valve on there.
Old 03-14-06, 09:48 PM
bolide's Avatar
The right valve has to be turned only 1/4 turn to go from ON to OFF.
> i did get all 90s with a copper sweat inlet, and the out is male/threaded
most likely 3/8" male compression thread but could be 1/2" npt.
Correct.
> but i went and bought another plumbing book and this book says to
> the valve on there.
That is entirely unnecessary if you got the correct valves (see above).
But take care when soldering not to overheat the valve itself.
Old 03-14-06, 10:22 PM
N
now i'm sure i've got the wrong ones
mine look like this
http://img100.imageshack.us/img100/3918/dscf12081rw.jpg
they take several turns to close.
Old 03-15-06, 01:26 AM
bolide's Avatar
Of course they will work... for a while.
But eventually they will cramp up and not close or they will leak.
I very much dislike them.
The bottom line is that someday you'll need to shut the water off in a big hurry and they won't work.
You want chrome angle ball valves with 1/2" copper sweat by 3/8" o.d. compression male.
Where I get mine they are a buck cheaper too.
