Code Question regarding compression fittings
someone who knows, please refresh my memory. i was forced to install a 3/4 inch coupler behind a finished wall. what does the upc say about this? am i supposed to install an access panel? i thought i learned once upon a time that compression joints required accesss panels?m.
Need more information regarding your exact situation, pictures and so on. Not supposed to put any compression connections of any size behind finished walls. If you do, an access panel is required. You didn't mention new construction or old, if it was a repair/remodel. Need more info to answer the question.
