Angle for toilet vent
Old 04-05-06, 10:24 AM
A
I know that vents have to attach to the waste line at a 45 degree angle. Can a toilet vent run at (almost) horizontal, under the floor, after leaving the waste line until it gets to a wall cavity, where it turns straight up?
-Antun
Old 04-05-06, 11:25 AM
A
This diagram shows what I mean:
http://www.antunkarlovac.com/stuff/b.../horiz_run.jpg
-Antun
Old 04-05-06, 01:09 PM
steve_gro's Avatar
Received 1 Upvote on 1 Post
Yes it can - sometimes there isn't any choice. I would use either a long-turn 90 or 45/st 45 where it turns up. Drain fittings below the flood level is code in my neck of the woods.
Old 04-05-06, 01:46 PM
A
Thanks for your reply. What does the flood level mean?
-Antun
Old 04-05-06, 10:57 PM
bolide's Avatar
-- the maximum vertical height above the earth's surface that water can backup until it runs onto the floor.
In the case of a sink or toilet, that's the rim of the bowl.
If the water gets any higher, it "floods" your bathroom.
Old 04-05-06, 11:08 PM
bolide's Avatar
> I know that vents have to attach to the [horizontal] waste line at a 45 degree angle.
Whose rule is this?
Here's what I'd do if there is room:
At the bottom of the vertical vent, use a 60 elbow.
Run pipe over to the drain line.
Put on another 60 elbow aimed straight down.
Add a short piece of pipe to connect vertically to the soil pipe.
Old 04-11-06, 11:07 PM
steve_gro's Avatar
45° or better.
Old 04-12-06, 12:38 AM
bolide's Avatar
Originally Posted by steve_gro
45 or better.
Correct. 90 >= 45. A take-off 90 is fine.
Perhaps antun saw that same diagram. The key is >45. It doesn't have to be exactly 45.
Thanks for the diagram. It needs work so as not to confuse people. It should say "more than 45" or "45 or more".
