gas valve water leak ?
Old 04-16-06, 04:38 AM
daswede's Avatar
I know it must sound crazy,but there are a few drops of water under the gas valve to my hot water boiler occasionally.
Could this be just condensation? I checked the area around the valve,but there isn't any source of water near the valve.
Anybody have any thoughts about this?
Thanks
Old 04-16-06, 05:11 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
It probably is condensation. Even though small, there are restrictions in the valve. When the boiler calls for gas, the flowing gas causes the valve to heat up a small amount but enough to change the temperature of the metal.
Old 04-16-06, 05:25 AM
daswede's Avatar
Whew!!! Thanks!
Happy Easter. (hope i'm not out of line)
Old 04-16-06, 06:21 AM
Thanks, and the same to you. If you want to ease your mind a little more, mix up some dish soap and water and brush or spray it on the valve. It will show bubbles if there is a gas leak.
