kitchen sink with new plumbing wont drain
Old 05-08-06, 01:33 PM
Exclamation kitchen sink with new plumbing wont drain
The plumbing underneath the kitchen sink wont drain. The plumbing was replaced using pvc pipe. with a ptrap. the plumbing appears to be connected correctly but it will not go down the main drain. could it be connected wrong is there a certain angle that you have to have I am not a plumber but this project looks correct before connecting the new pipes the sink had not been used in two weeks can anyone help me?
Old 05-10-06, 08:05 PM
steve_gro's Avatar
Assuming that the drain is installed correctly, I would run a snake down the drain to clean the obstruction. If you aren't comfortable with that, call a rooter company.
One other long shot: if it's a new drain that was installed with permits & inspected, the plumber would have plugged the drain to fill it with water (as part of the inspection). If it was 5:00 on Friday, the plug may have been overlooked. Drains can be plugged at a cleanout for testing.
HTML code is On
