pvc to terra cotta
Old 05-17-06, 05:50 PM
C
pvc to terra cotta
I am in the process of remodeling my basement bathroom. New shower and moving the toilet.
after cutting up the floor and running new pvc pipe, I am forced to splicing the pvc into the old existing terra cotta.
I was just intending to use a 3" rubber sleeve w/ clamps. However, after cleaning up the junction (and remaining concrete), I am left with the fat end of the existing terra cotta (the end where the pipe slides into). I don't have the option of cutting up any more pipe (the pipe goes under the wall and into the sewer).
I am wondering if there is a way I can do this to avoid leaks (and smells)?
is there a rubber sleeve that has an internal clamp that expands, or am I dreaming?
also, should I put a toilet flange on before pouring the fresh concrete, or only leave the pipe sticking out of the floor and using a flat flange with rubber o-ring type seal (and attach to to the floor with tapcons or something)??
Old 05-17-06, 06:25 PM
Received 521 Upvotes on 426 Posts
Fernco make a lot of different size fittings.
Measure your two pipes and go here.
http://www.fernco.com/coupling.asp
There should be one that fits your needs.
Old 05-18-06, 04:56 AM
C
thanks, I think I found one that will work, I'll just have to unearth a liitle more pipe... thanx!
