Cut water line
Old 05-27-06, 02:37 PM
A
Cut water line
The pipe is copper and supplies water to the toilet. Before repairing the water damage to the ceiling below, and finishing the flooring I was doing, I need to fix the pipe. It is copper and I believe it looks like it is an inch or smaller. The pipe has a cut through about 3/4 of it. I've never cut a pipe before therefore I have never had to fix one. Suggestions?
Old 05-27-06, 02:43 PM
davido662002's Avatar
re
you'll need a pipe cutter, if it easy to get to a hack saw blade, emery cloth, solder, flux,torch, and a female female copper connector. shut your water off, I know you already did that..
Old 05-27-06, 03:57 PM
A
can you go into detail a little more detail
on those intructions? So I cut the pipe off evenly with a hack saw and then what? Also how far apart do I need the new ends of the pipe to be?
Old 05-27-06, 04:23 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
Once you cut the pipe, buy a slip fit coupling. These couplings do not have a "stop" in the middle so you can pull over one side of the pipe and slip it on and out of the way after cleaning it. Mark (with a pencil) 1/2" from the cut. Apply solder paste and slide the coupling to the mark. Then you are ready to sweat the joint. I have included a link on how to sweat copper. Good luck.
http://www.doityourself.com/info/h2handlecopper.htm
Old 05-27-06, 06:24 PM
A
Thumbs up
thanks, we'll see what happens.
Old 05-28-06, 04:24 PM
A
Everything worked. I'm almost suprised.
Once I cut the torch up a little bit more and really got the cupling cooking the solder started to flow. Cut on the water and not a drip. Thanks.
Old 05-29-06, 02:18 PM
