clear silicone or plumbers putty
Old 05-29-06, 06:25 AM
My drain assembly for my one piece shower is pvc...the metal strainer is screwed to the pvc which also screws on....whats best for sealing the shower lip/strainer to keep the water from getting on the floor under the shower? silicone or putty? Thanks
Old 05-29-06, 04:17 PM
steve_gro's Avatar
Received 1 Upvote on 1 Post
Smile
Are you trying to re-start this age-old argument again ? Some plumbers like putty, others like silicon. I use putty in some places & silicon in others. Putty contains oil, so it is not used on marble or anything else that might stain (putty will stain marble after a period of time).
Bottom line is, it doesn't make much difference, but in that particular application I would lean towards using 100% clear silicon. Cleanup with alcohol, and you have to be quick.
Old 05-29-06, 04:53 PM
I bought both today and am leaning towards the clear silicone....
Another question....I have a cultured marble vanity top Im doing as well, will the putty stain that too...not sure the difference between marble and cultured marble? will it stain?
Old 05-29-06, 05:06 PM
majakdragon's Avatar
Plumbers putty will stain any type of marble. Use the silicone on both jobs. Good luck.
