Low Water Pressure
Old 06-05-06, 02:14 PM
cheenulee
Low Water Pressure
hi all
I recently remodeled the bathroom and replaced the tub fawcett stems (separate hot and cold water). For a while it worked great, but now i get a sudden loss of water pressure in the hot line. opening up the hot fawcett stem cures the problem, but I am wondering what could be causing this? Thanks for your help,
Old 06-05-06, 04:33 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
If all you did was replace the stems rather than the entire unit, you may have purchased an incorrect (too long) stem. It doesn't take much. Remove them both and switch them to see if it happens with the cold water. Post back with results.
Old 06-19-06, 12:15 PM
cheenulee
working again
Hi Chandler
turns out that the Packing nut (I think that is what it is called) was loose and just needed some tightening. I should have tried to take it apart first instead of posting first. anyway, works good now. Thanks for your help.
