PEX and Chemicals
Old 06-09-06, 02:02 PM
P
PEX and Chemicals
I have read that PEX can be affected by petroleum based products. When sealing around PEX pipes where they pass through a wall can spray foam be used to seal the hole? Along the same line can spray foam be used around electrical wire in the same situation?
Old 06-09-06, 08:37 PM
Look up the product name of spray foam and check out the MSDS specs.
It will give all statistics on what flammability levels are and other points to consider.
I would say yes without a doubt that it can affect PEX.
