Saddle Valve Question
Old 06-11-06, 06:53 PM
This valve does not completely shut off the water to my heating humidifier. Can I safely tighten using pliers? Would turning the packing nut do the trick?
Thanks
Old 06-11-06, 07:39 PM
R
Thanks
A saddle valve is not the best valve. (they always leak or do not work) You can try to turn the packing nut but be carfull.
My suggestion would be (if you know how to solder pipes) is to replace it with a 1/4" ball valve.
Once you do that you will not have any more problems.
Old 06-11-06, 07:55 PM
Saddle valves are not code in my area and are not to be used. They clog up easily and leak over time.
Old 06-11-06, 09:07 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Not to mention the pittance of flow they allow. I always like to install a tee with a ball valve installed on the side of the tee. More flow, less leak, less clog.
