anti-syphon valve leaks
Old 07-18-06, 07:51 PM
The anti-syphon valve on my outside faucets have major leaks. How do you remove the existing valve if the screwhead was tightened until it snapped off?
Old 07-19-06, 07:31 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Small drill, small ez-out. That's the only way I can see to get it out. It will be brass, so it is fairly soft, and easy to drill.
Old 07-19-06, 10:34 PM
F
Received 39 Upvotes on 31 Posts
Are you sure that the screw is broken off? All of the add-on vacuum breakers I have seen used Allen (recessed hex) setscrews. Look closely, it it already looks like a hole exists in the screw it probably requires an Allen wrench for removal.
Old 07-20-06, 03:29 AM
majakdragon's Avatar
Received 1 Upvote on 1 Post
mawmaw, Welcome to the DIY Forums.
The screw may have been intentionally broken off. When I worked in Florida, it was required that we break off the screw after installing the anti-siphon device. This prevented anyone from removing the device. Easy-out and drill, as mentioned, may work. Good luck.
