cpvc
Old 08-10-06, 01:05 PM
P
Received 6 Upvotes on 6 Posts
cpvc
Someone replaced a cold water shut off fitting with the type that has a cpvc lining which you cement on instead of a compression fitting. Trouble is I need to replace the fitting as I'm replacing the vanity and they only left me about 5/8" or 3/4" at the most before I'm at the wall.
Is it ok to cut the fitting off then apply the cleaner and the cement for a coupling to extend the pipe?
Also, how long is it reasonable to wait to turn the water on-The reason I ask is I have a finished basement and have to shut off the house water-I've read people say two hours is what they do and others who say 12 hours is necessary. Thank you
Old 08-10-06, 01:45 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
As long as you have room, use the coupling. I know they say to allow 12 hours for the glue. If you buy a quality glue (Oateys etc) you can go 2 hours. By not using the water to that valve, you will have an air space (no water) and it will cure more until you use it. Good luck.
Old 08-10-06, 02:14 PM
P
My house originally required shutting off the pump to work on anything. When ever I did any plumbing I always put a valve in so I could shut down just that section. While you have the water off . . .
Old 08-11-06, 09:26 AM
P
cpvc
Thanx for the information, it helps.
