Extending the water pipes
Old 08-17-06, 11:45 AM
K
Hi-
I am remodeling my home and need to move the washe/dryer from the kitchen to the adjoining mudroom.
For the existing water location, I would like to install a small kitchen sink and extend the water pipes for the new washer location.
I have full access to all pipes from the basement; I noticed that the horizontal copper line (I think 3/4") is reduced to 1/2" approximately 2 ft before the verticle 1/2" leading to the existing washer location.
I am not sure if I should just solder additional 1/2" solder run (additional 4 ft then verticle) or I should "split" the 3/4" pipe into two 1/2" runs.
Can you check the picture and let me know what you think?
Thanks!
Kevin
Old 08-17-06, 09:25 PM
L
i cant open pic but i would stay with the one line and add the 4ft if you split it you might get lower water pressure to both
Old 08-17-06, 11:13 PM
steve_gro's Avatar
Received 1 Upvote on 1 Post
The URL should read:
http://img155.imageshack.us/my.php?image=plumbingsetupcf1.jpg
(you have to copy & paste it; don't know why it isn't clickable)
I would go with option B, but extend 3/4" to the branch & use 3/4" x 1/2" x 1/2" tees. Sorta like option C but cleaner.
