winterizing water softener
Old 09-26-06, 12:58 PM
L
Question winterizing water softener
I have a water softener in the garage of my lakefront cottage.Will it freeze in the winter with all the salt in it? If so,Can rv antifreeze be run thru it? I plan to blow out the water lines and put in antifreeze .
Old 09-27-06, 11:15 AM
I dont think I would go that route. You would be better off disconnecting the softener, draining it, then storing it in a heated place. Then reinstall next spring.
Old 09-27-06, 06:07 PM
Niadh's Avatar
I'm not sure about Antifreeze and a softener. There could be gaskets that antifreeze would eat thru. I'd call the manufactores of the softener and ask them. The salt only keeps water from freezing down to around 0 to 15 degrees F.
