draingage from dishwasher problem
i am having a problem with my dishwasher the drainage pipe is connected to a v shaped connection with the washing machine drainage pipe before being connected to the outside drain
everytime we use the dishwasher some of the water ends up in the washing machine is there any kind of valve i can fit to the drainage pipe that will let water out but not in if so whare can i get them
drain
I think that you have some kind of bogus hook-up.
The dishwasher should not be hooked up to the wash machine drain, normal procedure is to hook it up to the garbage disposal or to a connection to the kitchen sink drain before the trap.
A v type connection; I don't know what that means, are you talking about a wye in the stand pipe?
A little more info. may help solve this problem.
"If all else fails, read the directions"
