Stainless Steel Kit sink, rim to counter sealant
Old 11-03-06, 12:44 PM
trane's Avatar
Mounting a S.S. kitchen sink to formica counter top using mounting clips, what is the sealant of choice?
Old 11-03-06, 01:26 PM
T
Received 2 Upvotes on 2 Posts
Clear 100% silicone.
Old 11-03-06, 05:00 PM
T
Run a bead of the silicone caulk around the edge of the cut out for the sink and drop the sink in.
Old 11-03-06, 05:48 PM
W
Received 13 Upvotes on 11 Posts
Hello, When I change out a sink I use a whole tube of caulk. I run a bead on the cut out itself right on the bare press wood then I smear it all over the raw wood. I try to seal the press wood a little water will cause exterme damage. I then caulk around the cut out paying close attention to the rear where the faucet will be. When I set the sink I put two clips as close to the faucet as possible. Single handel faucets have a tendency to cause the s/s sink to flex and break the seal.
Good Luck Woodbutcher
Old 11-04-06, 04:39 AM
trane's Avatar
Thanks
Thanks for all the help!
P.S. Woodbutcher that was a good thinking with the clips!
