running gas line to a new location
Old 11-14-06, 08:47 AM
I want to run natural gas to our laundry room. The home is not currently plumbed for gas to this room. I believe I can see a route that will work to get it there but I have a few questions.
What are the issues or guidelines for running a solid gas pipe through floor joists or sill plates? Is there a minimum hole size to allow for natural movement in the structure?
Is it even wise to run a gas pipe through floor joists?
Are there flexible gas lines that exist for permament use inside the walls? Are they generally considered to be safe for permanent use?
Anything else I should know or consider before doing this?
Scott
Old 11-21-06, 10:03 PM
B
strap 1/2" black pipe to the bottom of the joists, using 2-hole straps. Get pipe into laundry room, add a sediment trap and a shutoff valve. Then run metal flex pipe from valve to the dryer.
suggest coming up into laundry room as close to wall as you can get--don't try and route the pipe thru the sill plate.
Old 11-21-06, 10:18 PM
T
where i am you can run a copper lin then call a fitter to check and tie in and you dont have to worry about blowing up!check sizing and codes beforehand
