Clogged Kitchen sink
My kitchen sink has two sinks with a drainage in each sink.
One drainage is for water draining only and the other has a garbage disposal. It seems both are clogged and when I put a plunger on either one it pushes water up to the other drainage hole.
I also tried draino and other chemicals and it is still clogged.
Please advise the best way to clear the drainage in my kitchen sink? Should I try a snake in both holes??
try this...
the water pushes up the opposite drain because they share the same drain line under the sink. So, what you can do it fill the sink with enough water so the pipes are filled with water. Then put the drain plug in on one side and hold it in tightly while you plunge the other side. This with allow the pressure you build with the plunger to attack the clog and not blow out water on the other side of the sink. if you cant get it this way your gonna need to rod it. Its better not to use drain cleaner because if you do and it doesn't work, you get the gift of having to rod a drain with acid in it.
first thing to try is to boil largest amount of water you can and pour it down the drain , usually its grease and this can sometimes melt it enough to get flow .
be careful though with the chemicals in there ,
snake it jake right to the main-line!
If this fails get a contractor plummer
Remove t line going into main and run a snake to unclog, suggest motorized snake for one man operation, feed snake downward towards main to unclogg. It is best to try this then to spend ninty dollars to have a plummer do the same. Rent one for twenty dollars for four hours Home-depot of some other tool rental establishment!
Go under sink where it goes into wall!
Nice catch Gunguy45
I think they keep these for others with the same problem to read. I am new to this moderation stuff, so I don't touch them. But I should have caught that one also. I was reading it getting ready to add my reply.
For those reading my post here, I am pretty sure you can narrow the age of posts at the bottom of the page if wanted.
I try to remind myself that whenever a reply is from a new member I should check the date of the OP. Obviously not foolproof.
I can understand why the posts are archived but I don't understand why replies to old posts are allowed.
Received 38 Upvotes
I understand the archive but not the allowance of the new post on an old, old topic.
