dripping faucet
Old 11-29-06, 04:58 PM
T
dripping faucet
we just noticed that are tub faucet is leaking, what could cause this? What should I check first? Thanks
Old 11-29-06, 06:04 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
I am assuming the shower diverter is resuming a "rest" position and allowing the column of water to be extricated from the vertical pipe to the shower head. If all is well there, we will need to know what type faucet you have. Brand, single handle, three handle. Then we can probably give you a step by step way to solve the problem.
Old 11-30-06, 10:43 AM
I have the same problem! I have a single handle.
thanks
,Scott
Old 11-30-06, 06:15 PM
chandler's Avatar
Scott: is has one handle, but is it a flow mixer which turns on and then you adjust for hot or cold, or do you turn it counterclockwise at a constant velocity moving from cold to hot as you go?
Old 12-01-06, 01:08 PM
ya, you turn it counterclockwise from cold to hot
