Replacing Resin in Kinetico Water softener
I have a Kinetico water softener which is about 9 years old,
The dealer claims that the resin is gone bad and replacement cost
is about 350$
Does anyone know if it is simple enough to replace ot yourself
Which type of resin is recommended in this and how much is required
And where Can i buy this type of resin.
Best Regards,
is about 350$
Best Regards,
Resin should last longer than 9 years, unless you have some really hard water with lots of iron. I dont think it is rocket science to replace the resin yourself. Im guessing you are going to be spending close to $200 for the resin plus shipping. Just a guess though. I would try one of the online softener companies such as Ohio Pure. They can also tell you what kind of resin to use.
My home has the City water connection, I don't think it should be too bad
Is there some documentation on web on how to replace resin, I know it should be pretty simple but I have no idea about how water softners work and what goes where, except for filling the tank with Salt.
The primary reason for resin failure on city water is the chlorine. Actually, 9 years is typical for resin life without chlorine removal. Kinetico's warranty on resins are shortened on softeners without dechlorination.
Replacing the resins, depending on the model, is not difficult and I can help you. The replace cost by the company is about right for that kind of service charge. There are a few different types of resin you can get, some more efficient than others and cost may reflect quality.
Andy Christensen, CWS
