shorten water line
Old 12-05-06, 08:29 AM
K
shorten water line
I live in a mobile home, when handyman fixed leak for hot water line underneath; he shorten the line causing it to pull loose from tap fitting. how can I lenghten and re-connect to tap fitting? thank you kay
Old 12-05-06, 09:03 AM
shacko's Avatar
Mobile home leak
The hot water line goes to where?
What is the line made out of?
What are you calling a tap fitting?
Sorry but this is not enough information, re-post and someone on the forum may be able to help.
"If all else fails, read the directions"
Old 12-06-06, 12:18 PM
K
kitchen sink
it's the hot water line to the kitchen sink, it's plastic and does not reach the faucet connection. thank you kay
Old 12-06-06, 03:24 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Kay, if it is the gray line from the cut off to the faucet, it is cheap enough to replace the whole thing rather than trying to fix it. They come in varying lengths and are easily cut to length. You can also get braided stainless lines that are easy to install also. The fitting at the sink is probably 1/2" while the one at the cut off is probably 3/8". Post back if this is not the case and we'll take another spin.
Old 12-07-06, 06:38 AM
shacko's Avatar
Mobile home leak
Agree with chandler, just buy a new supply and replace, they don't cost that much. Lots of luck.
