PEX De-Crimping
Old 12-09-06, 11:57 AM
PEX De-Crimping
Is there an easy way to remove a crimp connector from PEX tubing? I've heard there is a De-crimping tool but I have looked all over town and no one seems to carry them. I was wondering if there is another way to get it off.
Thanks!
Old 12-10-06, 09:51 AM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Not sure why you would want to "decrimp" pex fittings. You should not use the old fittings back, and certainly should not use the old crimped pipe on a new or different fitting. Just cut the pipe behind the fitting, discard the old fitting and start over with new ends and fittings.
Old 12-10-06, 03:16 PM
Because it is a brass fitting 1/2" copper sweat to 1/2" PEX. The crimp is 1/4" from the brass "butt" and is probably fine but I would have liked to have the crimp a bit closer.
Obviously I would need to cut the pipe and start with a new end but why would I toss out a perfectly good brass fitting? (Not to mention unsweating the joint to install a new one). I know there is a tool for this.
Old 12-10-06, 04:57 PM
chandler's Avatar
Knowing this in the first post would have gotten a different answer. That is why we are sometimes perplexed and have to ask questions. Look at ebay 280049389855 Is this what you want?
Old 12-10-06, 08:20 PM
Dremel tool .
Old 12-11-06, 02:59 AM
Sorry for the confusion. This is the only type of PEX fitting that I am aware of. Yes, that is the tool. I already have the crimper but I can't seem to find the crimp remover anywhere locally (which brings me back to my question) is there another way to remove crimp rings?
Thanks
Old 12-11-06, 03:01 AM
Originally Posted by JimmieDee
Dremel tool .
Thanks! This sounds like the answer!
