Any tips for cutting cast iron pipe?
Old 01-29-07, 04:06 PM
martin_30's Avatar
I have been at my 4" cast iron pipe with my sawzall and not making much progress. I'm using a Dewalt metal cutting blade. Is there something better that I should be using or does it just take a day to do it?
Old 01-29-07, 04:22 PM
wrmiii's Avatar
wrong blade
Go to a plumbing supply and pick up an eight inch carboloid blade. It takes about three minutes on four inch pipe
Good luck
Old 01-29-07, 04:26 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Most rental stores have a chain cutter to use to cut the cast iron pipe
Old 01-29-07, 04:30 PM
B
rent the soil pipe cutter or try a tungston blade in your sawzall...8 teeth per inch..as you hav found, higher number of teeth only polish cast
Old 01-29-07, 04:49 PM
F
Received 39 Upvotes on 31 Posts
A thin, high-speed abrasive cutting disc works pretty well. If you don't mind destroying the pipe then a BIG hammer will also work.
Old 01-29-07, 10:28 PM
G
Received 31 Upvotes on 29 Posts
You must have a very dull blade or a DeWalt fake or your angle to the dangle is incorrect. I have cut a few and I have a cheap sawzall, however, one cut one blade. Good luck and have a nice day. Geo
Old 01-30-07, 08:17 AM
shacko's Avatar
Cast iron
Agree with furd. If you have 4 1/2in. grinder get a cut-off disc, that will only work if you can get all around the pipe. A standard sawzall blade thats not making any progress is usually a waste of time. You can also buy a blade thats designed for cast iron, [plumbing supply]. Lots of luck.
"If all else fails, read the directions"
