PVC Cement Types
Old 02-03-07, 04:08 PM
F
PVC Cement Types
I plan to use some flex PVC to re-plumb my hot tub. Of course, the couplings and such will be regular PVC.
Am I correct to assume that I use the PVC flexible cement on the flex, and regular PVC cement on the regular PVC? And I can prime both with the standard purple primer?
Thanks in advance !!
Old 02-04-07, 08:53 AM
notuboo's Avatar
yes to glue.
You can use either purple or clear primer. Purple primer is used on jobs that require inspection because the inspector can see that the pipe was, indeed, primed.
Good luck with your job.
Old 02-04-07, 09:44 AM
F
Thanks. I"ve got some left over purple primer so I might as well use that.
I was also told that I could just use heavy bodied cement for both. Is this correct, or is it better to use the method I described?
Thanks again.
Old 02-04-07, 04:17 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Look into Rain-r-Shine. It is a thicker body, and can be applied with water present. Great stuff for repairs where you can't get all the water drained away from the damaged area.
Old 02-04-07, 05:11 PM
F
Thanks Larry. I ran across some cement in a blue can, can't recall the name, but it said it was multi-purpose; both for pvc and flex as well. Maybe I'll go with that.
Thanks again.
