water supply and drain layout kitchen sink
Old 02-08-07, 05:11 AM
what is the height of water supply and also the drain for the sink and disposal
on the wall inside the base cabinet
Old 02-09-07, 09:31 AM
F
Received 1 Upvote on 1 Post
Easiest thing to do is probably go to a vendors web site mand download the rough-in drawing. For example, go to the Kohler website, http://www.us.kohler.com/index.jsp
and navigate to a particular kitchen sink, go to the technical info listing below the description and download the rough-in .pdf file.
Old 02-09-07, 10:32 AM
shacko's Avatar
Height
If you don't want to calculate the proper height your best bet is to keep them low; too low will hook up, too high and you are fuxxed. Lots of luck.
"If all else fails, read the directions"
