RV Sewage Dump Install
Old 02-23-07, 11:37 AM
P
Question RV Sewage Dump Install
Im in the planning stage of installing a RV dump site on the side of our home. I want to tap into the line under the restroom(toilet) Does anyone know if this would be a safe option.. Could i possibly damage the foundation?? Also dont they normally have a clean out next to a bathroom, on the exterior wall?? Would it be easier if i just dig a 80' long trench, to the front clean out?? Please advise.. Bill
Old 02-24-07, 05:07 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Welcome to the forums! The only drawback I can see is the introduction of blue water to the septic system. The natural enzymes in your septic may be damaged by the blue water. How many gallons at a time will you be dumping? Remember the capacity of your septic tank. For code purposes, dumping an RV may require the addition of a larger tank, since it will be considered another bathroom added to the house.
Old 02-24-07, 06:33 PM
Is this system being designed for multiple use as in more than just one RV?
Old 03-01-07, 06:51 AM
P
Rv dump
We are on a city sewer system, so we dont have to worry about damaging the septic. Im still up in arm's, as to if i should undermine my foundation. Please let me know if this is not a good idea
Old 03-01-07, 07:02 AM
P
Rv #
It is only for 1 RV. With a small 50 gal holding tank.
The RV parking is on the S. side of the home. On the inside of the home, just about where the dump station is lined up there is a bathroom. I want to either tap into that bathrooms plumbing, or make a 80' run of pipe to the front yard and tap into the main. Which do you think would be a wiser choice? With going to the front im worried about keeping my 1/4'' per foot pitch going on. that would be 80' x a quarter inch..
Old 03-01-07, 02:16 PM
chandler's Avatar
Not sure I would attempt to tap into the bathrooms, although it is more convenient. You will have a 20" drop to the front yard attachment point, so how does that fit into things?
Old 03-01-07, 02:34 PM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
The first place to check on this would be your city permit department.
Their reaction to your plan would help you decide on the next move.
Old 03-02-07, 12:23 PM
P
Excellent
Thank you guys for the advise!! I will check with our plans department at the city first! It may be a few weeks but i will post my findings ASAP!
