wet area in bedroom !
I hope this is not serious ! There is a small area in one of my bedrooms that has been very wet lately. I dried it up a few times but it keeps getting saoked with water ! This bedroom is adjacent to a bathroom. Before I assume the worst (like a water leak under ground due to a busted pipe), what can I check for to make sure it is not coming from under ground ? I really need some good advice here. Thank you very much !
How close is it to the bathroom(on the same wall)? Is the wet room on a cement slab? Are there any other wet spots in the room? Do you notice if its wet more after you do something in the bathroom or is it the same regardless?
