Help I have NO HOT water in my kitchen
Old 03-13-07, 12:09 PM
C
Exclamation Help I have NO HOT water in my kitchen
If any one can help I would appreciate it, the other day we came home and my kitchne was flooded, there was a leak under the sink well my husband turned off the water and fidgeted with some pipes and took apart the hot water side of the faucet well now i still have a slow cold water leak but absolutly no hot water what could be wrong?
Old 03-13-07, 12:43 PM
You are saying no hot water flow not that the water is no longer hot right?
Depends on what he took apart...and we are assuming he didn't just leave the supply valve turned off.Assuming the valve is on then it sounds like a dislodged washer in that valve or possibly the washer on the stem (assuming it's a conventional faucet design).
I suggest disassembling whatever he took apart before and checking for loose washers or any other blocking item.
Old 03-13-07, 03:25 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
In a water panic, you turn things off that you would normally not touch, so retrace your steps and turn back on the hot water supply from the water heater, or the stop under the sink.
