Relocate Natural Gas Pipe through Metal Stud?
Old 03-15-07, 08:25 AM
B
Hi. I'm currently in the middle refinishing my basement and need to relocate a black iron natural gas pipe. It would be convenient to move this behind a wall through the metal studs...is this a safe and acceptable location? There are no shut-off valves on the span that I need to relocate.
Thanks for your help!
Old 03-15-07, 09:16 AM
shacko's Avatar
Gas line
On the face of it, it should not be a prob. it may be a local code issue. Most codes that I work with will not allow unions or compression fittings behind the wall.
If you decide to go with the installation make sure that you do a test on the new run, it has to be 100% leak free before you seal anything up!
If you can, add a valve to the run. Lots of luck.
"If all else fails, read the directions"
