Stuff toilet brush in toilet
Old 03-18-07, 08:27 PM
Unhappy Stuff toilet brush in toilet
Help how do I undo this?
Old 03-18-07, 08:48 PM
Perhaps someone stronger than you can pull out the stuck toilet brush? If it is a wire brush, perhaps you can access the brush and bend the wire with your hands to release and pull out the brush. It is possible that the wire form squeezed beyond the opening and expanded. A regular plastic mounted brush could likely not get stuck. A worst case scenario would likely be to pull the toilet to remove the brush.
HTML code is On
