Pex...
Old 03-21-07, 10:40 AM
Pex...
I'm thinking about updating my plumbing in my old home and am thinking about using PEX. What would be the best way to make connections? Is crimping the best? I saw a tool being used on a this old house episode and it looked like it makes a better connection then crimping, but I can't find out information about the tool or technique. Anybody have anythoughts on the best way?
Thanks!
Old 03-21-07, 02:02 PM
G
Crimping is pretty much the only way to do PEX. There are some special fittings for 1/2" you can get, but they're pricey- they're good for tight spots where it's tough to use a crimping tool, though.
Be warned- you'll need at least 3/4" and 1/2" crimpers, and they're each over $100. Beg or borrow if you can! It's almost trivially easy to use though- PEX almost seems too cheap and easy to be real Just be careful to get the rings in the right spot before you crimp.
Old 03-21-07, 03:28 PM
T
Received 2 Upvotes on 2 Posts
Besides crimping... there is an expander tool that inserts into the tubing/ring - expands it so you can put it over a fitting - then when released, the tubing/ring tightens down on the fitting. I bought the tool new for around $169 as I recall - and sold it on E-bay when finished for $170... I really enjoyed the PEX experience - it was so much quicker than copper and solder.
Old 03-21-07, 03:54 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
The crimp tool has worked just fine for us.
Old 03-21-07, 04:11 PM
A
Wirsbo(sp) pipe, which is basicly PEX is the expanding kind. I haven't seen any problems with it yet. PEX pipe with crimp rings is a lot quicker tho. There are pros and cons with both.
