Toilet water supply question
Old 03-21-07, 04:42 PM
I just had to replace the flush valve in my toilet. I Also replaced the flexible water line. Everything is back together and working but I was wondering about the flexible water line. The distance from the valve to the toilet is 9.5 inches and the toilet and valve are offset about 1 inch. I replaced the 12 inch water line with the same, itís a steel reinforced one. The bend in the hose seems tight will I be better off getting a longer supply line which will allow for a looser bend?
Here is a picture
http://users.rcn.com/cmartorelli/DSCN3428.jpg
Thanks
Old 03-21-07, 04:56 PM
DaVeBoy's Avatar
If it's not kinked, you don't have a problem.
Old 03-21-07, 05:30 PM
Looks fine to me, too! So long as you don't have any undue stress at the couplings (could cause it to leak), you're OK. And it doesn't look too bad in that pic.
HTML code is On
