garbage disp.
Old 03-21-07, 06:34 PM
garbage disp.
the garbage disp. is leaking water from the bottom
no pipes are leaking. you can see it dripping from the bottom
is it shoot, should I just go buy a new one
Old 03-22-07, 02:30 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Sounds as if your disposer has developed a leak. How old is the unit?
Old 03-22-07, 10:09 AM
shacko's Avatar
Disposer leak
Buy a new one, the cost of repairing is usually more then the cost of the new. Luck.
"If all else fails, read the directions"
Old 03-22-07, 10:44 AM
Trying2Help's Avatar
Just because it is dripping from the bottom, doesn't mean it leaking at the bottom. If the unit isn't very old, all rusted up and looking like it has seen better days; look at the seal between it and the sink drain, if there is a line going to the dishwaser, check it out. Just make sure you find where the leak is starting at, not ending up.
If you find the disposal has a small hole, where the drip is seen...replace it.
HTML code is On
