Frost Free Repair
Old 03-22-07, 08:00 PM
G
Gen
Gen is offline
Received 18 Upvotes on 13 Posts
Frost Free Repair
Can a leaking frost free faucet be repaired? Unscrewing or unsoldering it isn't possible because the cellar area where it comes through is inaccessible due to remodeling--so it can't be easily replaced.
Old 03-22-07, 09:01 PM
GregH's Avatar
Super Moderator
Received 68 Upvotes on 62 Posts
After removing the packing nut on the outside the stem should unscrew then on the end you will find a washer.
Old 03-23-07, 04:34 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
If that washer isn't bad, or if replacing it doesn't stop your leak, then we will have worse news for you later on. Try the simple repair first, and let us know how it goes.
