need a 1.5 inch hole in concrete block wall
Old 04-02-07, 05:30 PM
I'm rerouting my sump pump lines and need to drill a 1.5 inch hole in a concrete block. How do I do that? Are there 1.5 hole saws for concrete?
Old 04-02-07, 05:41 PM
notuboo's Avatar
Rent a rotary spline hammer drill and a 2" drill bit. Either a Rigdid or Hilti will work great. 1 1/2" pipe needs a larger hole.
A little unit with a decent bit will have the job done in seconds.
good luck with your project...
Old 04-02-07, 07:58 PM
nap's Avatar
nap
nap is offline
New Member
cement block or concrete?
If it is a block, is the block filled?
If not and you have some leeway as far as placing the hole. a simple hammer will do just fine.
You need to find the hollow of the block (as opposed to where the web is) and simply strike the block repeatedly in the same spot. Hold the hammer so it hits the block squarely. You don;t need to hit it real hard, just multiple times. After you have an initial hole (which will be the size of the anvil of the hammer, you can peck around this hole to make it large enough for your pipe.
Do the same thing on the other side of the block.
Old 04-03-07, 06:03 AM
Received 120 Votes on 107 Posts
An electrician buddy of mine does it that way all the time.
Another option would be to drill a series of smaller holes [regular drill and mason bit] and then knock or chisel out the remainder.
Old 04-03-07, 09:14 AM
shacko's Avatar
hole thru concrete block
Agree with marksr and nap, if you make a mistake it is not that hard to patch, I would not rent a hammer drill, overkill, lots of luck.
"If all else fails, read the directions"
Old 04-03-07, 04:56 PM
I think I'll use the drill/small bit method. A day's rental for hammer drill and 2" bit is $55.
Thanks for the suggestions!
HTML code is On
