Foreign Object in Drain
First, I am a RENTER! (I figure that's kind of important to know b/c I have no ambition to tear anything apart.)
Second, I bought a drain brush to move along hair and whatnot from my tub drain. I stopped pushing the brush down the drain when I hit something about 5" down. I began to pull it out & tugged once. Then it BROKE off leaving the brush INSIDE the drain. UGH!
What do I do?
I'd love to show pics of both the brush and the type of drain I have, but apparently the IMG codes are turned off for this forum.
In any case, it's an old tub with an old drain -- the kind that requires a plastic stopper if you want to take a bath.
What do I do?
You can post pictures on a site such as photobucket.com and let us know the url. Before we go too much further, can you access under the tub, say from a crawl space or basement?
Making something to reach down into the drain and hook the brush isn't a bad idea but use thinner material than 5/16.You'll have a difficult time bending this thickness of stock.3/16 would be easier and do the job.
Here's the best pic I could find of the drain brush -- http://i53.photobucket.com/albums/g50/Alicia_in_NYC/201%20Gates%20Ave%20Apt/DrainCleanerBrush.jpg
And here's a pic of my drain -- http://i53.photobucket.com/albums/g50/Alicia_in_NYC/201%20Gates%20Ave%20Apt/IMG_0097.jpg
AND, NO. I cannot access a crawl space. I am in the second floor apt. of an old Brownstone-type building.
No. I cannot see the broken end. I just posted a link to view two pics...the pic of my drain was taken *after* the brush broke off.
I've never heard of "all thread." Is it just heavy duty wire? I like your thinking!!
A salesperson in a real hardware store can help you pick out what will work best from their stock.
all thread is just a long steel bolt without head , it would be the last thing I would try.it would be very difficult to bend a hook with all thread
talk to the guy in the hardware store and get some brass or copper rod .
(or try a coat hanger )
You should be able to use a small drain snake and just bend the tip out a little for a hook that will snare the brush tip, then you can pull it out. Have a good one. Geo
No. It's just an old type of drain. I posted a link to a picture of it in one of my previous posts.
Not yet -- although I will either tonight or over the weekend. (The last few days have been haired what with getting ready for the holiday & all.)
First, I will try the coat hanger technique. Only because where I live in Brooklyn, going to the nearest hardware store involves a lot of walking, a subway, and a bus.
Believe me, I will *totally* let y'all know what happens or happened...and of course, ask more questions if I find I've opened Pandora's Box!
