new shower stall
Old 04-09-07, 01:06 AM
D
new shower stall
I bought a new fiberglass 1 piece shower unit and want to install it but not sure if I can just attach the drain pipe to the old shower drain I have. It was a homemade shower stall with a concrete floor and a wall around. The old drain is in the concrete with a drain cap on top. Can someone tell me what I need to do to install this? Will I need to tear up the concrete and install a new pipe? I can send some photos tomorrow if need to see more closely
thanks
Old 04-09-07, 09:23 AM
shacko's Avatar
Shower install
If you bought a new shower there should be dimensions that came with the unit, these will determine if the original drain will work, I have my doubts. Without knowing the actual situation this is the best answer that I can give you, sorry.
"If all else fails, read the directions"
